I am venting a pellet stove to the outside wall from my finished basement (2 foot above gradient). After the inside wall thimble, beyond the studs I am at concrete block with a stucco exterior.
My question is, do I need to use the thimble on the outside or can I just run a 3.5" hole through the concrete block and stucco to run the vent pipe directly out and not have to enlarge the hole to fit the thimble (I will be adding a 90 degree bend to cap off the pipe at 3-4 feet above ground level)? If so, can I use concrete patch inside and around the vent pipe in the concrete and stucco around it after I put it in (to seal it in place, similarly to a dryer vent)?
Thanks in advance.
Thanks in advance.
