We finally have our upstairs chimney put in. However, not sure about the last piece. The chimney went like this...
4' Telescoping pipe on top of the stove
4' piece of stove pipe
6" slip
ceiling box and adapter, then the Class A
Now, I've had some confusion online, a lot of places refer to the telescoping pipe as slips. However, Ventis had the telescoping pipe marked as just that, and this piece marked 6" slip did not telescope, it just fit into the ceiling box adapter. My question is, the 6" slip had holes for screws in one end, the part that fit into the plain stove pipe in the middle. The 6" slip did NOT have holes drilled in it for the ceiling box adapter, nor did the ceiling box adapter have holes drilled into it.
Do we need to drill some pilot holes for screws there, or does it just sit as is? The 12" slip downstairs was the same. Just slid onto the thimble adapter, no pre-drilled holes for anything. Everything, and I mean everything else had pre-drilled holes.
And code requires a minimum of 3 screws, correct? Or do we need to put in all 4?
6" slip
