Sorry, lots of info to try to explain. I am not a HVAC tech. I have a background as a trained auto tech and I've remodeled a couple houses.
This unit is installed in a studio apartment at the inlaw's, where we've lived the last two winters. It is the primary source of heat but has to be supplemented by electric heaters in MN winters.
The unit in question is a Vermont castings DV25 Stardance. Its a 25,000 btu unit. It is running on propane. I'm told it has never put out enough heat to warm the 20'x20' studio apartment and that it was a disappointment from the start. It does have a blower that turns on automatically when the unit gets warm. The inlaws had it installed about 10 years ago when they moved in. They've had 2 techs come out to work on it over the years. Neither one was able to get the thermostat working(I replaced the thermostat with one that has a battery and now it works.) One tech broke the glass and inlaws had to cover the cost of that. I can see from the paperwork the gas valve was replaced in 2012 at a cost of $362. Nothing made it put out more heat.
You can see my reluctance to call a tech again, it's a small town, not too many options.
The new gas valve has a sticker that reads lo .9-hi 3.5, but the adjustable knob on the front says 2.8-11 WC so I believe it was converted to LPG correctly. I bought a Manometer and am reading 11 WC input pressure and up to 10.2-10.3WC output pressure, BUT sometimes the output drops slowly to 8.6 or so and then shoots back up to 10.+ I'm not sure if the input varies too, I didn't test it as long.
Complaints:
Seems like it should put out more heat/ doesn't seem to get hot enough. How hot should this unit get? As it is now I can place a candle on top of it and it will never melt/get soft.
The unit doesn't always run when it should, and it shuts off sometimes. After I got the thermostat working I thought that it would run when it should at least but I noticed that sometimes the big burner (main burner?) wouldn't be on when it should. If I hit the piezo sparker sometimes this will make the main burner come on, even though the pilot is already on.
Sometimes with the big burner running it makes a soft popping sound, like popcorn but quieter. This can be intermittent or almost constant, but again not very loud.
I'm concerned that when it isn't running, but should be, that not burning LPG is running still and costing me money for nothing/and is dangerous.
As I write this the fireplace is to my left and the manometer is on the output pressure test port. The fireplace has come on and off three times in the last five minutes and the pressure has gone to 0 when the flame goes out. The hi-low knob is ALWAYS on high because on low the flame is weak and I think the shutting off problem is worse.
Complaints:
