I have an LP Vermont Casting Radiance Stove (circa 2013).
Few weeks ago I had a Gasket Door Heat problem that was solved with the help of this Forum.
Until now when the Pilot is On and I started the Stove within 1-3 second the main Fire would start and worked well.
Now Pilot is still working, but when I start it takes 20 or more sec. and it start with a rather scary "Boom".
After the Boom it immediately calms down and work as it should.
I did some search and it seems that since there is a delay in catching the fire too much Gas accommodates in the chamber and then it ignite with a Boom.
Functionally it means that when the stove is used with a thermostat it happens every time when it goes Off and On. Beside the unpleaabt noise it is probably dangerous too.
So... what shell I do How can I fix it.
TIA
TIA
