I built a walk in cooler recently.  It is 5x5x8 and uses an 8,000 btu air conditioner.  I am using an inkbird temp controller and a johnson freeze sensor.  I am trying to eliminate thermal leaks.
The blower housing seems to be a very good heat exchanger, since it is just a thin piece of plastic. The air returning to the room is 2* different than the air going into the unit when the compressor is not running. I measured a 15* difference of the plastic inside the housing and the blower moves 200 cfm.
I punched the numbers into a heat exchanger calculator and it said I am "losing" 10,000 btu/day just through the blower housing. That is a full third of my thermal energy. I am planning on pulling the a/c unit and insulating the blower housing. I never would have thought that an air conditioner would have so much energy loss in one little area. I have thin flexible foam sheets that I will use on the housing. My other option is spray foam.
Does anyone have any better ideas? Are my numbers way off? The rest of the cooler is air tight. R25 walls and doors, r40 ceiling, r15 floor over concrete. 2 interior walls, 2 exterior. One interior door and one exterior, again, both are r25+. All seams are sealed. Doors are gasketed/weather stripped. It is physically impossible to slam a door unless the other door is open to release the air pressure.
i have never heard of anyone insulating an air conditioner blower, but it makes sense that it would be a high loss area with high airflow and temp difference. Please let me know if I am out in left field with this.
