Hi-
My father-in-law gave me a hand this weekend putting up Durock cement board with 1" space behind it for my corner install wall shield. Used metal studs on the flat screwed to the wood studs, then used 3 1/4" Tapcons to go through the Durock, the metal stud, and the drywall and ultimately into the wood stud.
The next step here is to use some tin ceiling tile to cover the Durock. The manufacturer of the tile indicated we'd want to nail this to the Durock, however I'm a little hesitant to start nailing on the Durock as it seems brittle - we'd probably need to pre-drill but then what holds the nail into the cement board?
My question is this: Can we use a high heat silicone adhesive/sealant like this instead of nails?
(broken link removed to https://www.rutland.com/p/4/600-degree-f-rtv-high-heat-silicone-sealant)
Obviously it would probably smell until it cures, but outside of that it seems like it would work.
Thanks for any help!
