The shield is built one inch off the wall with steel spacers. The space is open at the top and bottom to allow air circulation. The stove is 18 inches from the shield in the rear and 17 inches from the side. The flue DuraVent is rated at 6 inches to combustables so no need for any additional shielding to walls.
I have looked at lots of heat shield installations online. It seems 24 gauge sheet steel is recommended in the one place I can find any sort of "official" mention of gauge. What I used, largely (no pun intended) because of area I wanted to cover. I installed galvanized 29 gauge grade 80 so a pain to bend in the corner. This is not as thick as 24 gauge. Twenty-four gauge to cover the area I covered would have required a special order and would have been difficult for me to transport and install.
I fail to see how modestly thicker metal would have a meaningful difference, but I intend to put a remote thermometer behind the shield to check temp. during a hot fire.
Regarding online pictures I viewed of stove installations ......I am shocked there are not more stucture fires.
STJP
STJP
