Was your epa wood burning stove, a leaning curve for you?
HuskyMakk
6
NL, Canada
I just got my Blaze King Princess installed on March 10. I’ve had experience recently with my in-laws new Blaze King, King 40, so I did have some experience from a week of using theirs in January. There is a bit more to the use of the EPA catalytic stoves, but it’s by no means rocket science. I don’t know how I did without this Blaze King all these years. I can’t wait for next winter! Lol. They’re awesome stoves. The time between reloads is amazing. I highly recommend them. Being so good for the environment is kind of just a bonus for the user.
vbu
Burning Hunk
Mar 3, 2019
227
MS
Anyway yes there will be a learning curve for every stove, epa or not. Even switching between epa stoves, there will be a learning curve. How steep that curve is, depends on your prior experience but its certainly not rocket science.
Reactions: EbS-P and Itslay90
Itslay90
296
Upstate,NY
Well thank you
EbS-P
4,845
SE North Carolina
Dry wood really helps the curve. As does a thermometer.
buc74
Burning Hunk
Oct 16, 2012
192
Fort Atkinson, WI
After 11 years of burning I feel I'm still fine tuning my burning. As ebs-p added, dry wood really helps the curve.
BKVP
I think managing the proper burn rate (heat output) has been the biggest learning curve...every year! One day it's 48 and the next 75, which requires me to watch the weather forecasts more closely. I have a King 40 and "normally" I load the stove full each and every time. However I tend to not do that as much during the early shoulder seasons with the swings in day time highs.
My learning curve is more about the weather, the type of fuels and their attributes in burning and draft than it is the stove itself. To be fair, I went from a pellet stove to a early EPA stove to BK, so there was and always will be some learning, but again for me it's not som much about the stove as it is the above influences on how the stove will heat my home.
BKVP
Reactions: HuskyMakk
xman23
2,566
Lackawaxen PA
It can be, and you get better at it year after year. It does require paying attention to what works, what doesn't and why. My first few years I thought totally blackened glass was going to be the norm. Now It comes natural to do most ever burn, big or small, a few hours or days and the glass has no more than a little white haze. In those early years my oak was not seasoned as well as it is now. But I think it's that I run the fire cycle much better now.
If you know the basics of how to get a good hot fire going, it should be a easy learning curve. The goal for most of us wood burners is to minimize the work and time. I try to make the house temps so comfortable you can't tell the stove is the only heat regardless of the outside temps.
begreen
Mooderator
Staff member
Nov 18, 2005
100,853
South Puget Sound, WA
Most new stoves will have a learning curve, especially if the design, firebox construction, or technology is different. It often takes a month or so to get used to a new stove, especially when the draft dramatically increases due to a sudden drop in outside temps. The learning curve can be harder if the stove is located in a basement due to the remote, out-of-sight location. A wireless thermometer helps in that regard.
Even after one is used to the stove, there is still some continuous learning due to the variations in the wood fuel and draft. Burning wood is part art and part science.
