Hey, guy48065
1 - Gas valve off.
OK...was thinking maybe some ice build up on the cap & the small amount of heat from the pilot caused a melting
2 - Not immediately apparent--I'll have to look more closely (move the stove) next time. The stack is old installation--all I did was run the liner.
OK...If the water ran down somewhere, it'd leave a trail of deposits
3 - The gas pipe is caulked where it enters the brick.
Eliminates THAT one!
4 - Not sure exactly what you mean. The cap is a high wind cap (Simpson) & vertical.
My Bad. I could see it went horizontal but I didn't realize you'd run a masonry adapter/liner
It was a big PITA to install the liner and connect it to the cap & the stove adapter. Distressing to think that's possibly where the water is coming in.
Yeah, been there...when you were installing the cap, how did the "mudcap" look? That's generally where the leakage occurs...The seam where the mudcap meets the terra cotta flue tile is generally where the first water penetration is...It'll get in a little ways & freeze & make the seam a gap & more water & more freezin & you get the pic...
Quick fix is good ole 30 year clear GE silicone...GOOB it on liberally & you can avoid getting a mason up there for a while...
Don't wait for a follow-up investigation ;-) It'll probably be a couple months before I go up again. The water isn't a real big deal to me but I was concerned it might be a brick problem & could get worse. I like my stove (yes-Stardance) & the look of the brick but that big uninsulated brick surround sure takes a long time to warm up. Efficiency probably wasn't a thought and codes were non-existent back when this place was built.<.
K...but like I said above, freeze/thaw cycles can cause mor than a little bit of damage once a leak starts...
