Hello all,
TL:DR At the bottom.
Hoping for some input or advice here. My house has a 2 story fireplace in it with 2 flues. One flue vents the main floor fireplace, the other vents the basement fireplace. Every spring that I have owned this house (2021 to present) I have had water begin leaking through the bottom two or three layers of brick and mortar in the basement (see pictures).
After consulting with a chimney inspector, the first summer I dug out all around the chimney and did a bunch of waterproofing work. It happened again spring of 2023, so I had a new chimney crown put on, and a lot of the mortar chiseled out and re-tuck pointed (all done by a well-known and reviewed chimney company in town). It had some major cracks and decaying mortar joints prior to this.
I live in Michigan and it has been very warm with a lot of rain melting all the snow for this past week. Sure enough, this afternoon water started leaking through the brick once again. The flashing between the roofing and shingles got re-sealed with some type of caulk while they were up there too. I run a wood stove insert on the main floor and a pellet stove insert in the basement. Both of those are dry and have proper rain caps and stainless steel liners. The ash door clean out is on the exterior of the chimney, and the inside seems to always be dry.
Any ideas where to go from here? This is the only place in my basement that I get water leaks. I have no idea what to check next.
TL:DR The bottom of my chimney weeps water through the bricks every spring. Have rebuilt the top part of the chimney and had the flashing joints resealed. I have water sealed the exterior underground section. What do I look into next?
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323940-a36b05a2683a7273e44687e781a8e248.jpg?hash=xZelsqFU83)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323941-23a3b1e9dffd41711d00183e8e44eaa7.jpg?hash=BPvRDsnrL2)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323942-3738c222ed210ed54988f83a8b1a8c75.jpg?hash=Yie413LKzh)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323943-8a7e512a84373eaa6799cdd1cdc2e793.jpg?hash=Htsc3-3-MW)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323944-d96ce7881821c3f0b450198a75ca930d.jpg?hash=T5cmPv-ODE)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323945-c4277931fc17580c665de4b4edd63346.jpg?hash=9ZFH5vs5gn)
![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323946-bb45a9be9508eed012e28e167eefeb5b.jpg?hash=wTGQdHUBjs)
.![[Hearth.com] Water Leaking Through Brick [Hearth.com] Water Leaking Through Brick](https://www.hearth.com/talk/data/attachments/323/323979-0aab5790e9390735cc4554e8901a9d9b.jpg?hash=Tt66YPPpuD)
