I need a little help with our well pressure tank. First its a a small tank maybe 3-4 tall about 18" -22 wide. The tank is about 25 years old or so. The pressure switch was replaced about 4 years ago. What is happening is the pressure build and holds at 50 psi you turn something on it drops fast and holds around 25 psi. shut of the water builds right back up to 50 psi and shuts off. So do you think its the pressure tank or switch or both? Thanks
