Hand sanitizer comes in a squirt bottle already..but OP didn;t care for the residue it left behind.
Thats why I posted because it use the alcohol
The lamp oil trick works great for the Countryside and if use just enough to wet about 3/4 cup of pellets would get the stove quickly to temp so wouldn't need to baby sit and cycle the switch to satisfy the proof of fire. Hand sanitizer is available at most stores in the drug dept. Just try and get the stuff with high booze content. 70% or better.Until a few days ago, I used to use the auto-igniter on my Harman P68. The igniter just quit! (so happy to have found this entire forum about alternative --manual-- starter solutions.) I'm headed soon (today) to my local Lowe's or other store if need be to get either starter gel or hand sanitizer. I read that some (one person?) uses lamp oil........how does that compare to using hand sanitizer??
I hate having to use the heat pump for even short periods to heat the house.
May need to mix them up and not close the door all the way till the pellets are burning good or the air will snuff out the early fire. PIA process for Harman stoves. Torch method is more like a igniter. Just got a new torch and it had a leak in the head and when I pulled the trigger I removed all the hair from my hand. A Worthington, supposedly made in Sweden![]()
OK. I'll give that a try next attempt. The sun is getting higher in the sky....& outside is up to 57 F now....so, maybe I DID close the door too soon and the small fire just got gradually snuffed. (btw, the auto-igniter seems to have died a few days ago----is why I've been relegated to a new starting method.) THANKS!!
You forgot roaches and ants etc that love wood piles.--sometimes I wish I'd simply gotten a regular wood burning stove----except for the wood splitting and stacking aspect.
What is SuperCedar? Sounds like some kind of composite decking. Regionally available probably.tear off a small chunk of a SuperCedar sit in burn pot surround with pellets , light it wait a couple minutes hit on then ease the door closed. no residue
OK, I can see that. Using the igniter, my stove will "smoulder" for several minutes until it reaches that breaking point and then POOF.... out the flue flows a big ole batch of smoke.
Better be careful, our NSA is watching too![]()
What if they had arrested Timothy for being AWOL?Let um watch. They mess up where it really counts. If they're so good, how did they not know about the Boston bombing? Seems like they are spying on the wrong folks.
