What brush do I need?
Bmore
Burning Hunk
148
Baltimore MD
Hey all,
This will be my third season of heavy burning. I want to be able to clean my own flue but not sure what brush size and type I need. I have a 8" round flexible liner. Flue is 23' from top of box to chimney cap. Looking for a brush that will also clean the screening on the chimney cap. Last season the cap got partially clogged. Thanks for any suggestions of what I need and where to get it!
Not that i'm a pro, but one issue I envision with the cap is, It can be larger the chimney. With bottom up cleaning how does a 6 inch brush clean a 8 inch screen.
An 8" nylon brush, test before using and trim a little bit if needed (you want it to scrape the inside, but not to actually be distorting the liner).
To clean the cap, I'd suggest a cheap wire brush and a screwdriver. Take the mesh off and leave it off until you stop burning for the year. Knock off any remaining large crud with the wire brush. Won't have to touch the cap again until spring.
