I saw the Rutland products poly cleaning brush ..that ok? I have a stainless 6 inch straiht run chimney pipe.
Yes - it will do 45's without issue.Is the soot eater flexible enough to get around corners well? (not 90 degrees, but a couple of 45's)
Don't know, do you use a drill on the brush?
I was just looking at these on Amazon, how often does the line need replaced? Should I buy extra line when ordering or will the original last quite a few cleanings. I know chimney ht. and condition will affect the life of the line. Just wondering how it holds up for all of you that have been using them for a while.
+1 to that. I don't have a very steep roof, so I clean top down.Yep, I use the rutland 6" round poly and fiberglass poles on a 6" flex liner.
Thanks, I think mine is expanded metal but will need to check. Sounds like I'll be able to clean my chimney myself.If there is tight wire mesh on your cap then you may want to clean it more often. Mine doesn't have that but I still run the cleaner up into the cap and give it a couple of spins. I have a spotter outside ready to yell to me in the house when the sooteater enters the cap.
