what happened?!?!? What did I do wrong
Mt Ski Bum
535
Dillon, Mt
Ok, so I got back home to my new condo (see "I'm finally a indoor woodburner" thread) tonight & decided to start a fire in the fireplace. I put a few good sized logs on the fire after it got going, & also, I decided to take a reccomendation I got from my other thread to rotate the flue damper closed a bit to give the hot air a bit more time in the firebox. Then, I dicided to go upstairs to my room & do some organizing. Then all of the sudden I hear what sound like maybe glass breaking, so I go out & look down & see that one of the panels on the glass doors completely shattered & blown apart. I run downstairs to get a closer look, & right about then, flames & smoke start coming out the hole where the glass used to be- making the smoke detectors go crazy- the flames were huge & reached almost to the mantel. I quicky looked around for a fire extinguisher, none to be found, so I quickly grab several 44-oz cups of water from the kitchen sink & extinguished the fire.
It was kinda a bit of a scary experience, & while I am a bit bummed that my fire was cut short tonight, I'm just thankful that the condo didn't burn down or even sustain any damage other than broken fireplace doors (which are replaceable), & a few soot marks on the carpet (might be able to get those out with one of those shampoo vacuums).
So, now that the whole situation is over with, I want to know, what the heck did I do wrong?
Did I put too much wood in the fireplace?
Should I have left the flue damper 100% open instead of taking the suggestion from the other thread to use it to choke down the draft?
Should I have not cleaned the doors earlier in the day with fireplace/stove glass cleaner?
Should I have not went off to another room, & instead sit & babysat the fireplace?
Should I have left the doors open instead of closing them?
All of the above?
None of the above- just a freak accident?
:bug: Glad you didn't have a major mishap!
If it were me, I probably would babysit it until I felt like I could predict how it was going to react to various load sizes, air settings etc.
I don't guess that it has andirons to protect the glass in case a log shifts in the firebox?
Could the partially-closed damper have caused a smoke buildup in the firebox, which then ignited with enough force to break the glass? I doubt it , but...
Did the glass get too hot, too fast? I would think the glass would be designed to withstand this sort of thing...
Strange, and scary! I'll be interested to hear what everyone thinks...
I wonder if that glass was original and just regular glass. Either way be carefull.
When burning are you getting any smoke smell in the house? I see the area between the fireplace and mantle is quite dirty. If the fireplace doesn't draft really well to start with then I certainly wouldn't close that damper any while burning.
I'm no expert with fireplace doors. I wonder if some were designed to only be closed down when the fire was nearly out / out and this got to hot? The question about a shifting log hitting it is good also. Wonder if one broke in the past and someone replaced it with standard glass?
It may be time to find a sweep you trust and have him check this whole thing out top to bottom in person.
pen
I am glad no one was hurt. Consider a fire extinguisher. I have two that are charged with 10 pounds of sodium bicarbonate each. Consider connecting a fire hose off of the washing machine supply. Our 30 foot hose will easily reach all corners of our house. A quality garden hose costs very little, but is only useful for a minute or two. Significant smoke or heat and you should be outside. I am paranoid about fire, but am comforted by the fire extinguishers and the hose.
1. Have a pro come out to clean/inspect your chimney before you burn again.
2. In our previous fireplace, damper open = fire going, damper closed = no fire - - - - nothing in between.
3. Glass breaking - ALL the fireplace doors sold at the big box stores are NOT meant to be used closed with a fire going as they are not built with the proper temper glass. DO NOT close the doors with a fire going until you find out what type of glass is in those doors.
4. You said you are burning pine = pine burns very hot and very fast. Until you get used to how pine burns someone should always be in the room to supervise the fire.
Cool. There is nothing like watching a fire that is keeping you warm. I love the glass door on your fire place and on my Pacific Energy Super 27. Have fun and be safe with it. Keep that chimney clean!
Safety is always first! You don't want to close the damper to much on any old unit that you are not experienced with. I know you may not want to spend the money, but make sure that chimney is clean! Call a professional chimney sweep and get it cleaned at the least.
Now, I know you may not want to spend the money, but. Have you considered a new fireplace insert? They are more efficient, have better hot air circulation to heat your living space. Can be installed easily by an experienced person. And then you know you have a system that you can count on to be safe. And you will become familiar with it because you will be learning how to run a brand new unit. In the beginning it is an expense, but in the long run it will be worth it. Not an absolute necessity but just something to think about.
pen
all that soot below the mantel was there when we moved in- so that was done by whoever the previous tenants were. I have not gotten any smoke smell inside befere this "incident" I'm not too sure about a log shifting- the way the glass shattered & blew out doesn't seem like the work of shifting wood, to me at least.
I'm starting to wonder about the glass maybe getting too hot too fast- I remember when I reloaded it after the kindling & initial stuff burned down, I was suprised at how much heat it was throwing out already, with the damper at an angle. I think I'm done with the damper experiments from now on.
Gas- as much as I'd love to get an insert, I don't own the place, so it isn't up to me.
That appears to be a zero clearance fireplce like mine. The operator manual specifically says to never close glass door when burning. Only close the screen. I think it says that it has tempered glass and will break due to thermal shock if glass doors are closed.
Hey Ski Bum, maybe if you talk to the landlord he/she would split the cost of a new insert with you if you told him/her you would like to do some heating with wood. (I wouldn't tell them you broke the glass door on your second fire ;-) ), but maybe if you told them it would help to keep your heat bills down. Might be worth a shot if you could sell them the idea.
I too rent but I treat it and take care of it like its my own. I too had an open fireplace but I never considered burning it with the damper anything but wide open. I dont like the idea of dampering an open fire. I want no chance of carbon monoxide poisoning period. This year I cleaned up the firebrick, installed a 6 inch liner, and set a freestanding Buck in place. Should I ever move it all comes out in under 30 minutes and Ill leave the fireplace in better condition that when I found it. My landlord has no problem with any of this btw. Just my 2 cents.
PS, Bum Im no expert but like I stated in your other thread, something doesnt seem kosher with that soot in the images. I think its built up there for a reason. Maybe you could talk to previous renters or just ask the landlord. what they may know about it.
pen
Wow... I didn't think about the "Age" difference between yours and mine. Any experiments are done with me in the room (On any of my "Wood" burning appliance's).. Sorry to hear about the Door but I am glad no one got hurt. As mentioned above, Fire Extinguisher's are always a good idea (Own 3 of them). Along with Smoke alarms and CO detectors (we own 3 and 3/each area there is a "Wood" appliance). The Door set I bought, is from a Hearth Shop in Elyria, Ohio. It can be closed while fire is "Burning"..
My brother had the same problem with his 0 clearance wood fireplace glass doors. It was a cheep fireplace the builder put in. He replaced the glass a few times. Finally he went to a real wood stove store and got new doors that were made to take the heat. About then he quit using the thing. I would be careful. You are using this to contain the fire when you are not there, and you can't trust the glass.
I have a Marco fireplace on my main floor although mine is a 1990's version. My manual for it says to burn with the doors either fully open or fully closed. The damper should be fully open when burning, no in between. With that being said, I always burn with the doors open and the screen closed until it dies. Once it starts to die down I close the doors to go to bed or leave the area. I would not leave the fireplace unattended for long periods of time. It's ok to run out of the room for a few minutes but thats it.
You do also have to be very careful of logs rolling out into the glass if you burn with the doors closed.
I can't seem to find the manual for the fireplace anywhere in our condo- there's a manual for about every single other appliance in the place... except the fireplace. Go figure... But, I did read somewhere on the side of the fireplace behind the doors it said to burn with the doors full open OR full closed, so supposedly the glass should be able to take the heat when closed.
As for the reason I'm holding back from asking the landlord about an insert is mainly because he is trying to sell the place, & I kinda want to wait & see what becomes of that situation- if it starts to appear that it isn't going to sell for quite a while, or if he does sell it & the new owner is interested in long-term leasing it to us, then I might decide to approach him about an insert. Besides that, I need to build up a bit more money before I go shopping for an insert.
Gas- it broke on my 3rd fire... that's much better than breaking on my 2nd fire. :-P
As for the screen- I'd use it instead of the doors, but since they don't have any handles or anything, they're a P-I-T-A to open/close when the fire's going- they're obviously wayyy to hot to move by hand, so I end up trying to push/pull the screens with the fire poker, which is where the P-I-T-A part comes into play.
Also, is ~$170 a reasonable price for new doors? I found these: http://www.woodstoves-fireplaces.com/marco-fireplace-doors/ ... I still have to measure the fireplace to see if it's the 36" or 41" model... the firebox is approx. 20" wide in back & 25" wide in front, so I want to say it's a 36, but I'd better wait till I get back to Big Sky to make sure, so I don't end up ordering ones that don't fit. ;)
Also, as far as the chimney sweep goes- this will be my 1st time having to hire a chimney sweep, so what should I look for when hiring a sweep? Also, does anyone have an idea of how much a basic top-to-bottom inspection, like Penn suggested, would run as far as cost?
Also, one thing I haven't mentioned in either of my threads, but have been meaning to- the fireplace seems to have a really strong draft, which is why it seemed so odd that so much smoke came spilling into the room after the glass broke.
As for the soot below the mantel, I'm thinking maybe the previous tenants burned with the doors & screens open alot, which might let more soot build up on the rock face below the mantel- or possibly no one ever cleaned that rock face, so that soot's built up just a little by little until it looks like it did in my pics... or maybe the previous tenants had a door explode on them also.. ;) Just a quick side thought- alot of the open fireplaces I've seen pictures of have some soot build up in that same area roght above the firebox..
OK I just looked in the manual again for my Marco and there is a caution that reads " A fireplace with glass doors closed operates differently than a fireplace with an open front. With doors closed, the amount of air for combustion is limited. Excessive heat within the fireplace can result if too large of a fire is built or if the combustion air gate is not completely open or becomes clogged with ash." So it needs asking did you have a big fire going with the doors closed? This may have busted the glass?
I did have a lot of wood in there... what I'm starting to think is it was a combination of putting too much wood in too early (thus making the glass go from cold to hot quicker than if I slowly built up the fire), & having the flue damper at an angle (thus somewhat constricting the outlet for the heat & causing the firebox to heat up even more rapidly than normal).
I think from now on (once I replace the doors & make sure the chimney's ok), I'm going to
1. leave the damper at 90 degrees (all the way open) when burning
2. slowly build up the fire instead of throwing on a ton of wood as soon as kindling & smaller starter stuff burns down
3. only add a log or 2 at a time, to prevent the fire from going crazy
4. keep a close eye on the fire until it slows down- THEN I can leave the room.
5. see about getting a fire extinguisher or two for the condo- & maybe have a talk with the landlord as to why there aren't any fire extinguishers in the place.
As I recall my brothers glass would break anytime he had a hot fir and choked it down with the air control on the doors. It took him about 3 glass breaks to figured what not to do. It makes sense, with unlimited air flow from the front the heat goes to the back and up the chimney. Close of the air and the fire box and glass gets much hotter.
Also I would be very careful how hot you get this fireplace. Many of them I have seen are very small. They don't look like they should be used to replace a wood stove to me.
The way a fireplace works is once the brick is at an extreme temp, the heat radiates into the room, even with a 2 log fire. The fire itself gives little unless its roaring. You close the glass doors and thats a lot of heat. This was my experience anyway.
I decided to get the tape measure out & measure the dimensions of the fireplace just out of curiousity, & after researching inserts, I honestly can't find any that will fit in this fireplace- not even the Avalon Pendelton, which is super small, can fit in it according to the min. dimensions it provides.
Here're the rough dimensions of the firebox (they might not be exact, but should be pretty close):
Width (rear): 24"
Width (front): 30"
Height: 20"
Depth: 15"
Width (rear): 24"
Width (front): 30"
Height: 20"
Depth: 15"
Enviro 1200 should fit. Flue collar attaches on the inside of the insert, so don't worry about close height clearances. I have the Kodiak 1700 model and I'm very pleased with it. Very ruggedly built. Several aesthetically different models(Kodiak, Venice, Bostonian), but firebox is the same.
Width (rear): 24"
Width (front): 30"
Height: 20"
Depth: 15"
thanks for your opinion... A few months ago when I was at one of the local fireplace shops that sells multiple brands (Enviro, Napoleon, Kuma, Kozy Heat, Morso, Archgard, Mendota, & possibly a couple other lesser-known brands), & when I was looking at a couple Enviro brochures they had, the guy said they tend to stear people away from Enviro, saying that they don't seem to be as well-built as some of the others they sell.
I checked out the dimensions for the 1200, & it looks like it'd fit this fireplace in every dimension... except for the rear width- my fireplace needs to be 3" wider in the back. It seems like most inserts are designed for LARGE zc-fireplaces...
Also, I'm starting to think that if everything plays out like I mentioned several posts ago, since finding an insert to fit this fireplace is proving to be hard, I'm thinking about maybe replacing it with a free-standing Avalon Olympic, if the landlord approves.
Ski Bum...ya know, seems like you're trying to squeeze all you can outta that ZC. From closing the damper down when burning (yikes?) and probably burning it pretty hot, you probably lucky the place not burn down by now. With all the work and effort you got from cutting/loading and (I think you said previously) carrying wood up a number of flights of stairs, it's time to move to another place or get the landlord to make a decision and let you put something worthwhile in there. I hope you can soon change your signature from "dreaming" to "proud owner" of an Avalon.
this place is a different place than that one with the fireplace on the 3rd floor... this one has a nice entry-level great room with the fireplace in it- a much better layout! As for adjusting the damper while burning, it was suggested in another thread that if you put the damper at a slight angle instead of at 90 degrees (fully open), it'll help increase burn times/heat output a bit (& it did increase the heat output for sure- I'm thinking that might've been the problem), so I decided to try it, but I made 2 major mistakes- 1. I went to do something upstairs when I should've stayed downstairs to keep a close eye on the "experiment" fire, & 2. I should've kept the fire relatively small during the "experiment" until I knew how the fire/fireplace responded under the new conditions.
Either way, I too hope to be able to change my signature to "proud owner" of an Avalon before winter. I'll see how things play out over the next couple months with the landlord's efforts to sell the place (keeping my fingers crossed for a buyer interested in letting us enter into a long term lease so we can stay in this place for a while), & hopefully you'll see my signature change by winter to say "proud owner" of an Olympic- I'm hoping!
