I would love to get a big generac though not untill NG comes through my area in a couple of years.
I have a Yamaha EF2400 inverter style, for me it fits the bill perfectly. My main concerns during an emergency are heat, refrigeration and a couple of lights at night. My small housing development has a generator backed water system so no need to worry about water, normally that is a pretty big draw on power. For me the fuel efficiency and next to no noise is worth having to go without use of the dryer or oven for a day or two. This little Yamaha will run a coffee maker or the microwave if we choose to, just need to manage the loads properly, the plus is it is light enough and quiet enough to use for the occasional camping trip if we decide to take a few comforts of home with us!
I was set on getting an 8000 watt Generac until I saw how much fuel one of my neighbors used during an outage, his wife loved that they could go about their lives as if nothing had changed...until they ran out of fuel and the local stations were all closed because they had no power either! I listed what I really needed in a true emergency outage situation and that is when I decided on the Yamaha, I was also nervous after hearing issues with the sensitive electronics in pellet stoves not always liking the power of some of the conventional/cheaper generators on the market.
Almost every item out there isnt that sensitive as you think or converts the ac to dc anyway.
You sure it wasn't the giant dust bunny trying to stay warm off of the compressor and just smothered it?Running my stuff with a mod sine genny for the annual five to seven day outages finally ruined my fridge. After 28 years.
If a pellet stove or anything has an issue running off of a portable gen the chances are its a frequency problem due to the load be very light or it just being a cheap pos. the fix in most cases is increase the load to stabilize the gen to stop it from hunting and oscillating the frequency.
the issue is not the [power of the generator but the requirement of the control board (and other digital electronics in the home) to get a pure sine wave at 60hz .. standby gens don't produce a pure sine wave, expensive inverter gens like the little eu2000i Honda do..I find it hard to believe that a permanently installed standby generator wouldn't be able to power a pellet boiler.
I picked up a Chinese copy that's totally enclosed. Several paint jobs of the same engine genny combo with analog and digital control panels the first part of October and used camping for a week. Ran the old Profile Whit and several other items without issue. Once you go past 100lbs the definition of portable wanes in my opinion. I am used to diesels. Probably would not recommend one to most. I usually try to get everything up and running and tested a day or so before a storm is predicted. Have a small freestanding propain direct vent stove that can supply needed heat without electricity. 3 days without ability to leave home in winter in my area is not unheard of.I always tell folks to go diesel! When we lose power (or you are looking at a greater grid disruption)... gasonline will be VERY hard to come by. Diesel is what keeps this nation moving, fed, and protected. It is diesel reserves and refineries that will be the first to come back on, or be secured. It is of particular national importance that we have an undisrupted diesel supply. Plus it is a superior fuel in my not so humble opinion.
Want something bulletproof that will do way more than you ever need? Buy this, and fashion it onto a rolling cart (for lack of a better term) http://www.generatorsales.com/order/Slow-Turning-Yanmar-5kW-Diesel-Generator.asp?page=yanmar_4kw
Portable, with crazy good efficiency, and lower noise than any gas unit on the market.
Thanks...needed to hear this....lots of "information" out there to get worked up about...Robert of Cow Hill, VermontIn 99% of situations a modified sine wave generator or inverter will run anything you would ever care to power. Almost every item out there isnt that sensitive as you think or converts the ac to dc anyway.
Unless your running high end servers, or sensitive lab equipment it dorsnt matter. Its all myth and urban legend. You can run any household computer, tv, washer, dryer, oven, radio, pellet stove, furnace, anything under the sun darn near with no ill effect. A modified sine wave cant actually damage anything, it just wouldnt be qualified as a good source and the sensitive item in question just wouldnt turn on.
This is what i do for a living, trust me, it doesnt matter for the average joe.
Haha, you will hear all about it the first morning of a long outage when she steps into an ice cold shower! I am fortunate (kinda?) that my dhw is heated by my boiler. Rather than messing with my stove, the plan is to run the genny for lights, fridge and boiler. Providing full heat and hot water. I am tempted to get an inverter and deep cycle battery to run the boiler overnight. This using the car trick my be enough to sway me into purchasing an inexpensive 1k inverter. Can be used for camping or for powering the heat overnight!I have a champion inverter generator I got it refurbished here for $375. The RV folks swear by them. They also have excellent customer service I have a larger champion generator that had a fuel leak after a couple months they were going to send me a new generator when I called their 1800 number. I could tell what part was bad and asked if they could just send me that next day I had the part no cost.
http://supergenproducts.com/shop/refurbished-2000w-inverter-yellow/
A lot depends on what you want. I just want to survive comfortably I can do without running my welder during a power outage. Although I wont have hot water but my wife does not know that.
Can you set your boiler to "manual" mode where it goes into maintenance burn between calls for heat? I have not checked my stove with a kill-a-watt yet, but word of mouth is that most stoves run on around 100 watts and have a 300(ish) Watt igniter. A far cry from your pellet boiler. Once u wore up my furnace with a plug, i will check the draw on that too. Will be interesting to see the difference between an oil boiler and a pellet boiler.It looks like my new pellet boiler uses around 1300 watts or so when starting up (igniting). Is that similar to a pellet stove? No option for me to start up without electric ignition, I believe. Not much required once lit though. I'll have to use the juice from the Honda 2000i carefully when the boiler is igniting.
