Burning wet wood could damage the cat. So, technically, it could be more expensive burning wet wood in a cat stove. But, You can burn wet wood in either type of stove, you will just waste a lot of fuel burning off the moisture and it will be a gigantic pain in the ass regardless of the burn system the stove uses.Which is more detrimental though? I know neither scenario is good. Will the cat clog, versus sending 'sote up the flue?
I know all the drawbacks of burning wet wood... just interested in the difference behind the technologies I guess, and how they deal with improper MC levels.
So, knowing the drawbacks, why even attempt to get an answer? Technology has nothing to do with trying to burn water and until they figure that one out, we all need good dry wood.
I would tend to agree with that.I would assume secondary stoves, since they run at higher temperatures. Am I wrong?
It is just brutally annoying. Keeping the door cracked, closing the door, opening the door again, leaving the air controls all the way open, watching a sizzling fire as the stove sits at 300 degrees, then, after you have wasted half the load, the stove takes off and you are warm. But, you know in about 2-3 hours you will have to do it all over again. It is so freakin' time consuming.You get a lot less heat burning wet wood found this out my self also you have babysit the stove a lot more....
Dry wood all the way for me.
Yes, both cat and non-cat stoves can burn wet wood. Both are equally annoying when doing so. The cat stove could be more expensive to run when burning wet wood as you could damage the cat.Did we ever come to a consensus?![]()
I agree. I thought metalsped was refering to EPA stoves only for some reason. The Vigilant was also more forgiving to burning wet wood. It was still a huge pain, though.I would say a non-cat, pre-EPA cigar burn stove like the Jotul F118 or F602. The old dial type air control directs a pretty strong blast of air right down the middle. With dry wood it would be roaring and you'd close the air down almost all the way, then close down the pipe damper. But with poorly seasoned wood you would leave the air control more open and maybe close the pipe damper half-way.
