What is the best way to build the 1" air space behind Durock for a heat shield? Is there a specific manner it is to be built to comply with code?
I was thinking what would be the easiest is ripping strips of Durock (about 2-3" wide) or even cutting those strips into shorter blocks so that air can also move across ways behind the shield, screwing two thicknesses of 1/2" Durock strips to the studs to create the 1" void. Then either screw the larger (3'x5') sheets of Durock to those strips or even all the way through into the wood studs.
My questions:
1. Should I use 1 1/4" Durock screws attaching the Durock sheets only into the strips?
2. Or should I get longer screws (say 2" so at least 1/2" penetrate the studs) and attach the sheets through the strips and into the studs?
3. I was concerned that the longer screws would be a heat conductor directly into the combustible wood studs.
4. I was also unsure if the shorter ones would hold the weight of the sheets that will also have tile if they are only attached to the Durock strips?
I messed around and forgot to post this till the last minute.... I hope some of you Wood Stove Wizards get a chance to respond as it is getting late here. Any and all expertise or guidance on these issues would be appreciated as I am hoping to get the chimney pipe in and build my heat shields tomorrow, (on Sunday).
Thanks
Ed
My questions:
Thanks
Ed
