After doing a lot of reading here, it sure seems like more people own stoves than fireplaces. So I came up with three theories on why that is:
- Stoves are cheaper
- Stoves are more efficient
- Stoves look better
Seems to me that the efficiency is probably what sells the stove, but I haven't been able to find any hard numbers that compare the BTUs from a stove vs a fireplace (assuming non-catalytic and similar size firebox). Or how well it heats a given space, I suppose.
Comparing what I paid for a fireplace to what you can buy a stove for would argue that cost is probably an important factor as well. The fireplace surround and mantle can add quite a bit to cost and the fireplace itself isn't cheap either.
I'm not a big fan of a stove based on looks. Seems kinda risky with kids and pets too, but I imagine there are some people that like using it as a cookstove or putting a kettle on to humidify the house or whatever, so I can see that aspect as well.
When I built my place, I chose a fireplace mainly because of my wife, but chose one that could be used to heat my home (RSF Onyx2). In hindsight, I wonder if I might have been better off with a stove. My burn times are lucky to hit 8 hours and I don't ever have the problem of "cooking" myself out of the living room. It does put out a lot of heat, but nobody is walking around in shorts at Xmas time either.
Anyway...thoughts on what drives people to choose a stove over a fireplace?
What the OP has is an EPA-approved high efficiency zero clearance fireplace. (broken link removed to http://www.icc-rsf.com/en/onyx-2-fireplace)
