New to Hearth.com, and I've never owned a wood stove so any thought or suggestions would be greatly appreciated.
I have a 1200 sq ft bungalow on 2 acres. It was built in 1978, L shaped living room dining room faces south, electric furnace with baseboard heaters in the bedrooms. The basement is divided in to three sections , laundry/ mud room, bedroom, and 400 sq ft family room with open staircase in the middle of the basement. In the winter during the day we get a lot of solar heat coming through the windows even if it is -30, but soon as the sun sets you can feel the house get colder. The family room in the basement is around 60 f , and running a space heater barely makes it warm enough. I would like to put a wood burning stove in the south west corner, with an outside chimney. I would like it to heat up the family room with excess heat going up the stairs into the living room. Plan A is every day around 4 I fire up the stove and let it die out around midnight. Knowing I'll have to preheat the chimney to get the flue warmed up. Plan B I love the heat so much I run it all the time. Also if the power goes out for an extended period of time I would like it to be able at least keep the house warm enough that the pipes don't freeze. Thinking between P.E. vista 1.6 , P.E. Super le 2.0 , Enerzone 2.3. Last thing is the wood around here in western Canada is mostly poplar, pine or ash so that will affect burn times and heat output . Any thought on size? Or anything else. Thanks Brian
