With a mild winter and oil prices low.. What will pellet prices be next winter? Pellets are my only heat sorce and wondering what would be best for next winter... New oil burner? Or stick with pellets for next season..
"Pellets are my only heat source"
What does your homeowners insurance say about this, assuming pellets to be your "primary" and only heating source? Most insurers will require oil, gas, electric or similar, but not usually wood or pellets and view those as secondary or supplemental.
I would keep burning the pellets as long as possible, but I would also have the old stove ready to go Just In Case! Have the B.I.L. get it running in case the pellet stove fails. Start saving money for the new boiler if the B.I.L. says get a new one!If I had too I could fire up the oil burner.. My brother in law works on them and looked at it said its in decent shape and would run fine but I choose not too.. I would rather upgrade the furnace then go threw a tank of oil a month..
Yeah. I get it.The reasonning is this : Wood and pellet are both ways of heating that demand regular attention to work. If you were to unexpectedly be out of the house for some time, like you have an accident and are at hospital for some time, the heating will cease, the house will cool down and the pipes will freeze. Insurances would rather avoid this!
I give up.But if somebody bought a stove, flue pipe and tonnage of pellets because their primary source of heat was failing? That is insanity.
With the value of the dollar where it is I might consider a high efficiency german made triple pass boiler
I don't think it makes sense to switch to natural gas any more although three years ago it would have been hard to imagine oil prices where they are now and where they might be in the immediate future.
If you can afford to, I think it makes a lot of sense to have the most efficient systems at your disposal should you have to depend on either one. 1975 boiler has to be nearing the end of its expected life.
I think there's going to be more pressure on pellet prices than oil prices in the next couple of years. But I don't believe oil prices will be this low for long either. But I also don't see a lot of pressure on a big rise in prices either.
My pellet stove is my "primary" heat source when oil prices are high and then the oil furnace becomes the backup system. My third contingency for a loss of electric power to the house is the coal stove which needs no electricity. Myself and my insurance company have two different interpretations of primary and secondary heat sources.We have a lot of customers that have had both in their homes, the "furnace" crapped out,
and now there "only" heat source is a stove.......
