Hi, I have a Harman P68 which I purchased in June 2014. During the shoulder seasons, I like to run the
stove all night at a low setting. I was wondering. Which uses fewer pellets? A maintenance flame or
constant burn #1 (stove temp #1)? From what I can tell, I would say that the maintenance flame uses
fewer pellets, has the smaller fire, and produces the least heat - less than any setting of constant burn.
For those of you who have not experimented with the maintenance flame, you can run a maintenance flame
by setting the igniter switch to "manual" after you get the first fire in a room temperature mode.
A maintenance flame means your
fire never goes out, even when the thermostat (room temperature) has reached the set point temperature.
] I do run the normal room/auto in order for the stove to shut down in early afternoon or late morning juggling a feed rate of #2 or #4 depending on if I'm using small Lignetic pellets or longer of other brands I use.
