White stuff
closedknuckle
30
midwest
White build up on exterior of pipe
Anyone know what this is?
  • [Hearth.com] White stuff
How long has it been installed without being touched/taken apart?
Unknown it is at a friend's of mine. He bought the place last summer and pipe was black last fall.
Probably severely over heated pipe Probably a chimney fire. But the pattern looks odd. Also the pipe is upside down and clearances look questionable
perhaps the seller painted it for the home sale with non high temp paint. Then, it chalked up when it got hot.
Isn't that potentially deadly using galvanized pipe indoors?
Deadly? no... I could eat that pipe over time and survive. Some water lines used to be and still are galvanized.
Healthy, and, or advisable? Definitely not...
I believe the health risk would be in the zinc burning off, our bodies can handle some zinc and our bodies can process and discard it slowly. Lots at once can be harmful.
*Full disclosure, I don't know if anything I just typed is factual, it may be what I was told so that I would be comfortable working with and welding galvanized, which I do 5 days a week. We use an exhaust extraction hood while welding, it gets rid of most of the smoke. I feel no adverse effects 25yrs in...
I too have welded plenty of galvanized steel. The risk is way overblown, it’s not good to inhale but not bad like chlorine gas from mixing bleach and ammonia!
If it was actually galvanized, which I don’t think it is, then the bigger problem is that it is probably super thin ductwork pipe.
I’m guessing cheap paint and installed backwards letting water run out of the joints.
I was always told that when heated galvanized pipe offgasses deadly toxins and it should not be used indoors.
To each their own, but I certainly would not be putting any galvanized stove pipe inside my house and would not be recommending anybody to do it either.
Reactions: GG Woody
Nobody is saying to install or use galvanized stove pipe. That is a misunderstanding.
Be careful about reading the word toxic and jumping to conclusions. It's all about the dose. Even water is toxic if you drink too much.
You absolutely shouldn't do it. It is without question unhealthy just not deadly.
Where did that galv pipe come from? It's all either painted black steel or stainless now right?
No you can still buy galvanized pipe at most hardware stores for oil or gas connector pipe. It doesn't get hot enough to off gas zinc
It's also commonly found as ductwork. It comes in the same standard sizes as stove pipe so people see the price tag and pick galvanized.
It's hard for me to imagine that unless it were an emergency in an outdoor stove.
I think you nailed it. If I look closer I can see the angle slip joints. They probably had so many leaks they painted it with *** know's what
I don't think it will be approved as is
It happens all the time. There is no approval in the usa. Insurance is the only way it could become an issue
