Whitfield Advantage II-T HELP
astett1125
1
Maryland
Hello All,
I am hoping someone may be able to give me a little advice on my issue. I have a Whitfield Advantage II-T free standing pellet stove. I had just replaced the auger motor last week as well as the brass bushing/plate because the auger stopped working. This seemed to fix the issue. It ran a few more times and when i went to start it this morning- the auger light remains lit and the push to start button is not doing anything. There is power getting to the stove, because the auger light is red but wouldn't turn on the fans etc. I unplugged the stove in general and waited a few minutes to see if it would essentially reset the stove, but no luck. Any help/ideas would be greatly appreciated as I couldn't find anything online/on the manual.
Hello All,
Check the wiring between all the connections regarding the auger. The auger motor, depending on how it's situated can take itself for a ride back there and jostle a lot of connections.
Did you install the auger flange in the right position
If not the auger will rotate and pull the wires off
Reactions: ARC
