Whitfield Advantage Plus Stalling Out After an Hour or Two
GR366
5
North Shore, MA
At the end of last season, my Whitfield Advantage Plus started stalling out after running fine for an hour or two. Whenever it stalls, all the lights on the control board flash.
Last winter was my first season using the stove, and I am very new to this. For context, I did replace both the convection and combustion blowers last winter. Any help or advice would be greatly appreciated!
If your stove is equipped with high and low limit switches, try bypassing them one at a time and see if the stove will continue to run. This can also be done with the pressure switch as well.
This should only be done as a test procedure and the a stove shouldn't be run continuously with a safety switch bypassed.
