Who is painting their pellet stove this summer to make it look good for the fall?
Hello
Fired it up tonight!
  • [Hearth.com] Who is painting their pellet stove this summer to make it look good for the fall?
Lookin' good! But it's too warm down here for a fire!
Where did your friend get his equipment for electroplating?
Yes, I would like to see the pics!
I had some aluminum trim for a stove that I wanted to electroplate. There is a difference in setups for different materials. Not many shops around here do this anymore. There are some industrial companies here that only do high production runs for military or commercial parts. No small jobs.
There is one company that can do just about any type of electroplating for a price!
(broken link removed)
You can also buy do-it yourself kits. However, alot of time and setup. All you need is a variable volt DC power supply, chemicals, electrodes and some pans.
The best place OnLine for those supplies is Caswell. A good setup still costs a few bucks.
(broken link removed to http://www.caswellplating.com/electroplating-anodizing/nickel-plating-kits/ptfe-teflonr-electroless-nickel-kit-4-5-gal.html)
In many cases you have to run the same piece thru twice to get better quality results.
I don't know...wherever her chromes out his chopper parts I guess...I saw it in his chopper shop but it has since closed. He lives in Rehoboth though...I'll run into him again I'm sure
Thats on my list of stuff to do when I clean it. Since I named her Percilla the pellet pig I think I might paint her light pink. lol
Reactions: Lousyweather
I would never paint my stove and ruin the patina of rust and scratches built up over many years of loving use. ;)
Dave
Reactions: smoke show
Dave
Do you think this stove could use any paint?
As usual.
Hey Pete
Did you paint the firebrick copper and sand inbetween?
If so where did you get the paint? Did you use a brush for the mortar joints?
Awesome! ! ! Super Nice but please tell use?
How did you get the Surf Sand in the mortar?
Painted the whole thing the sand color, then taped off the mortar lines and painted the bricks.
The brick panel is all one piece. Pic below prior to painting.
Thanks tinkabranc
Hello
Any special masking tape? Did u cut the tape into strips?
Northline Express Order. Thanks Guys
Stove Bright High Temp Paint - Copper
5SA-8152
$12.90
Ordered: 1
$12.90
Stove Bright High Temp Paint - Surf Sand
5SA-8158
$12.90
Ordered: 1
$12.90
Yep, exactly what Tink said above as for the procedure to paint it. I used Stove Bright.
As for the tape, I bought a roll of auto body painter's striping tape (blue, 1/4" or 5/16"... I forget which) at local auto body supply house.
here are my before and afters from this year, first pic is how I bought it and ran it last year.
(broken image removed)
Sporting new paint Job. :)
Reactions: zrtmatos
Wow, it looks brand new!
Good job!
Thanks guys, not bad for and hours work sanding and prepping and 6 bucks in stove paint. I'm happy with how it turned out. I do wanna try something with the air grills on top though. Something like Dexter Day did with his and paint the glass trim the same color.
Just mask around the grills to make it rectangular. Leave about as much space on the edge as the width of one of the slats in the grill. Then using high temp paint, paint the edge and grills silver or gold. That would be cool?
Well, you guys talked me into painting my firebox in the Astoria! Does look shabby after 3 seasons! Real Nasty!
Prep is the hardest part!
Just got some new Wire Wheels for the drill from the new Harbor Freight store in Hyannis!
http://www.harborfreight.com/6-piece-wire-wheel-and-cup-brush-set-1341.html
So maybe with some Acetone and Elbow greese and these wire wheels I can make the paint stick? :mad:
Now I need some pin striping masking tape!
Hello
Still cleaning the firebox and firebrick panel. Got more emery cloth at Home Depot and picked up some 0.7" wide Rust-Oleum orange masking tape from AutoZone auto parts store. It seems to be the exact width of the mortar joint so it should work. The firebrick is still dirty so I have to clean it a few more times with Acetone or Firebrick cleaner which I also purchased from the local hearth shop.
