I've been experiencing some downdraft upon startup recently, like this morning. I can feel the cold air coming down the stack into the house. Cracking open an adjacent window helps. Opening the basement door did nothing. I don't sense any cold wind coming down the oil burner diffuser flap (or whatever it's called) in the basement. It goes away once things are warmed up, like after a piece or two of newspaper is burned. Annoying because smoke comes in the house if above routine is not followed. There were no mechanical draft sources on. Chimney 30' made of 6" stainless liner in a heatilator stack (stove is an insert) enclosed in an insulated chase. House is 2 floors, insert on first. Outside temp was 28F, 1st floor 59F, and basement 55F. I would think it should be cool enough for a natural draft. (Just thought of something: weatherstrip attic hatch - don't think that can be that much of a factor though - it's lying flush with insul on top.) House is a couple of years old, so should be pretty tight, generally.
The first time I got smoke in the house was a little disconcerting. Now, I take the above steps if I feel a cold breeze. Maybe it will be an occasional thing...just got the insert in March.
Opening the window, etc is an incremental hassle.
Any ideas?
Any ideas?
