I live in a 1100sq ft ranch in Maine where we tend to get some fairly cold weather. I’ve been heating the house using only an early 80’s Ashley circulator, rarely using our oil furnace as supplemental heat. While I’ve never had a problem with our Ashley, it’s starting to show it’s age and I’m thinking about upgrading. I’m leaning towards the englanders from Home Depot, but my worry is that while the nc13 would probably put out the right amount of heat for us, I’d sacrifice on the long burn times I need to make it through the night. On the other hand, if I went with the larger nc30, would I be able to run full loads at a low enough setting to make it through the night but not cook us out of the house? Any info on the matter would be greatly appreciated.
). You can always build a smaller fire in a bigger box, but not a bigger fire in a smaller box.
