Will metal clamp help to stop light smoke?
kingteto
22
CT
Hi All,
Just quick question. Regarding my pellet stove vent installation.. I smell light smoke and I see little smoke coming from the adapter pipe (1 pipe which is connected to the stove vent. see pic) .. can I put clamp to tight to the stove vent opening? I already put rtv but seems not enough , so is it safe/helpful to put that metal clamp they sell at homedepot ?
Thanks in advance..
[Hearth.com] Will metal clamp help to stop light smoke?
Hello
You must have a good mechanical connection before anything else will work! If that amount of Silicone does not work I would would brush it all off and check the connections and replace the pipe if needed. Also I prefer high temp foil tape.
Hello
Thanks for your reply.. Foil tape 350F is good enough for pellet pipes? or it has to be more than 350F ?
You can also try mill pack if you want. It's rated to 1050 degrees. That does seem to be a good amount of RTV. Like Don said It'd re check the connection replace what is needed. Are you sure that is where the leak is at?
Reactions: kingteto
Yes it's leaking from there because of the 90 degree elbow is hitting the stove shield so the adapter is not sitting even, but 95% is went inside.
Reactions: Owen1508
Correct this first or you'll be taping and rtving forever and a day along with not enjoying a smokey room.
