I am seriously considering a wood stove insert and plan on having one for next heating season. I currently have a simple grate heater, and it definitely is not doing the trick and using a LOT of wood AND at times seeping small amounts of smoke into the house through the non-airtight doors. I can only get it to maintain the heat my boiler puts out right now, and of course I can't keep it going through night. I've done quite a bit of research and know the Osburn 2400 would fit in my fireplace and am thinking I want to go as big as I can go. I want it hot in here ... seventies or even eighties would not be negative and in fact would be a very welcome atmosphere. I have a raised ranch with the fireplace on second floor. Lower floor is 1/3 finished, but I'm not concerned with heating that ... not much time spent down there in winter. The area I want to heat is upstairs, 1,100 square feet with about 600 of that open living area with cathedral ceilings in living room/dining/kitchen area (where fireplace is on center of outside wall directly across from hall to bedrooms/bathrooms). The chimney is about 20 foot. I think the house is fairly good insulated. I know the attic has about 8 - 10 inches I'd say and assume walls are properly insulated and no drafts from windows. I've been reading a lot of posts in other forums here which have been incredibly helpful and want to make sure I will be able to run a stove as efficiently as possible but also would rather slightly overkill than not be able to get at least 70 on entire main floor 24/7 in worst of winter with no help from boiler. Is that possible?
One more question I had is regarding the 6" liner required. I looked up my chimney and noticed I have a rectangular shaped liner right now that's definitely bigger than 6" on the largest sides but not positive if it's 6" on the smaller sides. It's pretty high up and with the grate heater in the firebox right now it's not very easy to get up to there to measure. Does anyone know if it's possible that it would be less than 6"? My house was built in 1992 if that helps.
And one last question that I have which I'm not sure if anybody else deals with but fairly important on this end. The open fireplace is an issue with allergies, but there's no airtight seal which I think is a huge factor. Does anybody have an insert or wood stove that they notice worse allergies in heating season? And in that vein, does the Osburn 2400 have a bypass damper that lessons smoke when opening door? Is there another comparable model that does have that bypass damper? Thanks in advance for any input!
