Disclaimer: Just joined. This is my first woodstove forum membership. I read the "read this before" section as well as the links. I have read more forums than I care to disclose. I have never had a woodburning anything in my house before. I am super excited to burn some wood though.
I would like your advice on whether the Woodstock Fireview will serve my needs well enough (other options I am considering are the Progress Hybrid and the Ideal Steel - unless someone can convince me otherwise).
Background: New construction (underway now) at 7300 feet elevation in the Black Forest. Tight build with spray foam insulation walls and premium windows. 8000 sf (about 2650 sf per floor). Main heat source will be radiant floor heat on all levels with large, efficient gas boiler. I have five acres of pines. I have cut, bucked, split and stacked about 4 cords to be used starting fall of 2016 (had to fell some trees for homesite). Pine and aspen are likely to be my only wood source unless I pay premium for hardwood.
Installation: Main (2nd) floor of a 3 story walk out. Placement will be along an interior wall in the 400 sf great room with 20 foot cathedral ceiling opening to a top floor walkway with banister connecting to kids bedrooms upstairs. There will be an interior chase with a height of 35 feet from great room floor to top of flue vent. The great room opens completely to a 550 sf kitchen off one side and a 250 sf dining room on an adjacent side with 10 foot ceilings throughout main level. So basically it is a 1200 sf L-shaped room with the corner great room opening up to next floor. Large wall of windows in great room face windward north. Between the great room and the dining room are two 6 foot wide exits, one to master suite and one to entry/stairway/hallway beyond.
I called Woodstock and the very kind lady recommended the Fireview with an outside air kit and a flue damper since there is likely to be a good draw given the height and interior location of stack. She thought the two larger stoves would roast me out if burned at an efficient temperature for the cat.
I honestly do not know how much I will burn. I would like to think it will be consistent through winter, but we will have fairly economical, even, radiant heat anyway. I think the stove will be a nice supplement to reduce our energy bill some, as well as enhance the esthetics of the home (I have fond memories of my grandparents wood stove growing up). Additionally, believe it or not, we have frequent spells of very mild weather through the winter here in Colorado Springs. I know I will not be heating an 8000 sf house with a single stove on a middle floor either. This is meant as an emergency heat source and a nice supplemental heat source otherwise. Seeing the fire is important to me as well, but it looks like I would enjoy any of the three in this regard.
What do you think of the recommendation made by Woodstock? Is the Fireview going to be big enough? Are the other two stoves too big for my needs? I like all three stove very much and have potential concerns with each design. My interactions with Woodstock have given me great confidence that I have chosen a first-rate company. I have no experience, however, and therefore would very much appreciate any input you may have.
Thanks in advance.
Christopher
Thanks in advance.
Christopher
But then again, there are hundreds of other stoves out there that all have their own pluses and minuses. No one said picking one would be easy...good luck!
But if you want cat or hybrid, that reduces your choices considerably...
