window gasket replacement Englander 25-PVD
hodder
3
Central maine
I am in the process of replacing the window gasket on stove. when I install the screws to that holds the bracket to hold the window in place they will not tighten. the screws had rust on them and also the hole they go into try cleaning by chase with tap holes seem to be oversized. any suggestions on how I can repair to get screws to tighten. thanks
Figure out what thread size you are dealing with, & increase it to the next size larger in diameter.
