Wireless Chainsaw Tach?
Turbo89
414
MA
Does anyone use a wireless chainsaw tach to tune their chainsaw? There’s a bunch on Amazon that say “wireless” but actually have a wire you wrap around the plug wire.
Does anyone have experience with those type or other types that are better? Looking for a low cost option that folks here have experience with.
AGPtek® Professional Digital Laser Photo Tachometer Non Contact RPM Tach​
Based on Amazon this one looks good. I guess you point it at the clutch? I've never done any serious tuning. We used to go by ear. Now all the carbs are made for EPA, or something, and you need "special" tools as you are "not allowed" to modify the emissions.
So here's the thing, even though the tachs have a wire that can be wrapped around the spark plug wire you don't have to do it. The pulse from the wire is enough for the tach to read without doing that so long as your kinda close to the spark plug. On a chainsaw you can hold it really close and get a solid read.
Yes, I use a "wired" cheap tach wirelessly to tune my saw. Just to set the no load max RPM and tune the high jet.
Reactions: Turbo89
First thing to note: many saws require special screwdrivers with unusually shaped blades to adjust the mixture, and there are several different designs used by different manufacturers. (The idea here is that the EPA doesn't want "Joe chainsaw owner" adjusting his own saw.) A lot of chainsaw dealers will not sell these drivers (they may not be allowed to either by the saw manufacturer or due to EPA regs?) You can find them on eBay and probably on Amazon as well.
There are two things you need in a tach used on chainsaws: one with a fast response time and which also will read high enough RPMs to cover the speed of a chainsaw. (Some of the cheaper ones intended for lawnmower or log splitter engines max out WELL below the speed of a chainsaw.)
Here is the tach I bought years ago which works well with chainsaws. It's recommended by a lot of the chainsaw repair guys I know. It's not cheap, but it does have a quick response time and handles the high RPMs. IT does have a wire you can plug in and wrap around a spark plug wire, but it also works without that if you can get it close to the spark plug (which is simple to do on a chainsaw).
There are other brands with a similar 1/2 second response time and ability to measure the high RPMs, but I've seen too many bad reviews on many of them to recommend them.
I would not use one that requires painting reflective marks such as the one recommended by Whiteknuckler, since that would involve running the saw at speed with the clutch cover removed. Since on many saws the clutch cover also holds the bar and chain in place, this causes a real problem. (Bar nuts on some designs might hold the bar without the cover, but still not something I'd want to mess with.)
Note that many modern chainsaws have rev-limited ignition coils, so the saw wont go above a certain RPM regardless of how you tune it. This can fool the unwary into thinking they have it set right, when in fact they are too lean.
It's also quite possible to tune a chainsaw by ear. Once you develop the ear for it, a lot of saw pros prefer it to using a tach. When I was first learning, I would try it by ear, and then verify what I got with the tach.
Here is one of the better YouTube videos I've found describing the process of tuning by ear:
Thanks for all the tips! I’m running clone saws (Wemar, Farmac), so I’d be surprised if they had any EPA anti-tamper devices.
Thanks for the tuning video, I’ll watch that too. I’m reasonably convinced the saw I want to tune is running rich, but I haven’t pulled the plug the check.
Yes, to sell them in the US/CA markets they were to have them by lawa long time ago. You can order the tools on Amazon. Just take a look but it is hard to see. If you try flat/star you may not get a grip.
Reactions: Turbo89
Interestingly, I just saw a YouTube video of someone ripping the plastic portion out so that they could use a flat head. 🤣
For the screws on my saws, the plastic portion is not what is gripped by the special screwdrivers, it's the metal screw itself.
Also: on some saws it is not recommended to remove the plastic limiters. There is a spring that presses against them keeping a bit of tension on the screw so the vibration does not cause the screw to drift to another setting. On my saws, I just took a sharp knife and trimmed the little tabs off the plastic limiters which prevented the screw from turning beyond a certain point. The body of the plastic limiter remained, but it no longer limited anything.
Reactions: Turbo89
Thanks! This is exactly what I want to do.
As the saw has been breaking in I noticed it bogs a bit more when I’m digging in hard on a log. I’m going to adjust the high jet to see if I can get her back to where it was; then check the plug to make sure it’s not running too lean.
I’m tuning a g372xp. Clone saw. No special tools required as these are clones of pre epa saws.
The clone saw carbs are known to take maintenance tuning. Some even replace with super expensive carbs if they can’t get it right.
Of course err on the side of too rich but Worst case you burn up a 25$ top end.
Nice! I’m tuning the 62cc Wemars (I’m not even sure what it’s a clone of, haha). It’s a beast compared to my old, tired Poulan.
I have a Farmac F380W (MS381 clone) with a 28” bar too, but I haven’t broken that one in yet.. so Im sure I’ll need to tune that one eventually too.
Never found the need to spend money on a tach
Tune by ear.
Learn what to listen for and then you can tune any tunable saw anywhere without any special tools.
A tach is not as reliable as your ear once you learn how to tune a saw
Reactions: Newbie78
Tune by ear.
As described in the bottom of post #4.
It really is a good way to tune a saw. However, it can take some practice to develop the ear for it, which is why I double checked with a tach the first few times I tried it. Once you learn what to listen for, it's easier, and many agree that it is a better way to tune a saw. Some folks just never seem to get a good ear for it, however.
Reactions: Turbo89
Well some of us are a bit challenged in the hearing department now days. Can't always catch that 4 stroke sound.
Reactions: Turbo89
That does suck
So far i have been lucky i guess as i rarely use hearing protection at 60+ being in heavy equipment and fixing it all my life.
Reactions: Turbo89
Just found this really thorough Stihl factory tune process. And it's only about 5 minute video.
Reactions: Turbo89
Interesting process, thanks for sharing!
being on the roa doing repair work and4 x 60+mph is the cause of most of my problem hearing wise. Course then there is the automatic tune out of the ex.
