This is my first post to the forum and I am a newbie to woodburing so I will aplogize for my lack of knowledge first.
My situation is that I recently brought a house with a fireplace and am looking to install a wood burning insert for astetics and supplemental heat. My current box is 37x24x26.
I am looking to cover most of the exposed wall to add two build in units on each side and a TV above the mantel. As a result, I lowered where the new mantle will go compared to the original. I was originally recommended to look into a quadra-fire. After much research, I am learning that in order to use a mantle below the recommended clearance I would need a noncumbustable and the manufacturer would need to explicitly state that. THe quadra-fire does not.
I was hoping I could get some suggestions of an insert and mantle ideas from experienced burners as it is not very popular in my area.
I attached a pic of my current fireplace with my new walls studded out.
Thanks in advance for those that read through my lengthy question.
