Wood Heat & Humidification
LocustBurner
81
Southside Virginia
For those of us not fortunate to have humidification w/ their HVAC systems, share what you are doing to add moisture to your home.
Currently use a lattice top 2 quart pan on the stove top's thicker, center burner and over the years we have used a variety of medium & small humidifiers with mixed results.
Started researching extensively last week when we noticed the indoor humidity feature on the new weather station hit 26, then 24, then 21 %.
Found this one on Amazon:
http://www.amazon.com/Vornado-Evap40-4-Gallon-Evaporative-Humidifier/dp/B00O0WOO74#Ask
but purchased it from Costco
http://www.costco.com/Vornado-Extra-Large-Capacity-Evaporative-Humidifier.product.100223910.html
as they included three additional sets of replacement filters (unit runs 2) for the same price.
Strong reviews on both sellers' sites.
Prepped after dinner and started with two gallons. Its been running for about 8 hours (used 2 gals.) and humidity has risen from 27 to 32 %.
Goal is hi 30s maybe even 40 %. Holds 4 gallons and is supposed to run 24 hrs. on full tanks on HI.
Which they recommend doing as you introduce the unit, then dial it back. Could run for 2 days w/o a fill up. We'll see . . .
Well water so we are trying this out (measuring exactly w/ syringe). Cleaning prior humidifiers was difficult to say the least.
http://www.amazon.com/BestAir-3BT-6...xgy_201_3?ie=UTF8&refRID=1R78X2PBK07352ZQXK0F
Seal your house tighter and you will also have more humidity, Woodstoves don't dry the air out like we tend to believe, what happens is that woodstove combustion forces cold dryer air into the home from the outside, its just something to think about.
http://www.essickair.com/humidifiers/large-home-2000-sq-ft.html
You can adjust the fan and the humidistat. I typically fill one of the two cannisters each morning. Depending on the model each cannister holds a couple gallons. On the low fan speed noise is tolerable.
Agree with Kenny, though oftentimes you cannot always address all the leaks (sliding glass doors etc)
House is very 'tight' already as 18 months ago we replaced a 20 yr. old slider with a new super energy efficient French door, changed out the old entry door w/ much better one, and have a full view security storm door on it.
Fairly new double glazed windows all around.
Actually just ordered a medium sized Vornado for master BR:
http://www.costco.com/.product.1149...vc=itempageVerticalRight|CategorySiloedViewCP
Costco again is supplying additional filters.
The large unit sits over the crunchy cat food dispenser and about 2' 6" from the Ideal Steel.
[Hearth.com] Wood Heat & Humidification
My wife bought an untrasonic one. It has a directional motor on it and acts as a night light as well. The kids love it and ask for it to be in their rooms. Air leaks or not, any home in the winter is dry.
(broken link removed to http://www.target.com/p/homedics-oscillating-cool-mist/-/A-14114903#prodSlot=_1_34)
We had to go the other direction by adding two dehumidifiers to the house. One on the main floor where the wood stove is and one in the semi heated basement. Windows were always soaking wet in the morning and had to be towel dried off. Our house is fairly new (rebuilt) and I believe is fairly air tight.
While the stove provides lots of warmth I am not sure, at least in our case, that it dried the house out. So many variables and each home has it own unique qualities.
Interesting information. Good luck with your scenario.
An update;
The Vornado is using about 1 1/2 gallons of water per day and humidity is between 30 and 36%.
The stove needs outside air. An outside air kit (OAK) is just a direct hose/pipe connection to the outside, so that the combustion air goes directly into the stove and doesn't get sucked into your house first. This would allow your humidified air to stay in the house and not go up the chimney. Just a suggestion...
?? Is the OAK to a Woodstock stove an "air tight" fit?? I recall a thread a few yrs ago, with I believe a summit insert, where the user indicated that the OAK fitting to the air inlet on the stove was not "air tight" and he reported noticing cold outside air blowing out the bottom front of his insert.
If you still need to add moisture, it is likely not a very tight house. Try sealing the following:
1.Wood mudsill where it meets concrete foundation.
2.Pull electrical panel cover and seal around wires coming through conduit into the box (Do your homework/be safe or hire electrician for this).
3.Seal around all pipes penetrating exterior walls.
4.Pull exterior light fixtures and seal/insulate at penetrations.
5.Pull all receptacle covers at walls facing outside and install insulating gaskets below.
6. Seal around all heating piping and plumbing piping penetrating the first floor from basement.
7. Seal around all recessed cans and other penetrations in ceiling.
8. Find any/all hollow chase walls and seal inside at bottom and top.
9. Check all exhaust fans to ensure internal check damper closing when not in use. Consider upgrade to modern fan and/or positive seal roof vent.
10. If replacing siding, consider using fully adhered exterior air/moisture barrier (Henry Blueskin VP100 or similar) instead of tyvek/house wrap, which usually is not properly installed or taped.
11. Check/repair/replace weatherstripping on all exterior doors , and at doors connecting to unheated garage spaces etc. Even new doors can have poorly sealing weatherstripping.
12. Windows of course.
This is the level of pickiness you need on a typical existing home built within the last 50-60 years or so.
This is air-sealing only....of course you should insulate the heck out of everything too, including hot water pipes.
OAK in place with tight seals
1.Done
2.na
3.Done
4.Done
5.Done
6.Done
7.Done
8. na
9. Done
10. na
11. na
12. na
The new Vornado humidifiers are doing the job.
Highly recommend them.
37% (78) in, 41 out @ 24 degrees.
I have a humidifier that boils water (1-4 gallons per day depending on the outside temp and humidity) in the stove room and a funky German air purifier one in the bedroom. The bedroom one is super quiet, takes a lot of gack out of the air, and needs no replacement parts- but it doesn't put out a lot of water (depends on ambient RH), and it does take a lot of cleaning for a humidifier.
