Wood ID please
The last huge round DOES look like cherry, colorwize. But Black Cherry bark is thin. Thin and flakey.
You might be doubting it because the tree is in different stages of decomposition. There is fungal and mineral staining.
Was the tree dead?
Walnut. Cherry has a wavier grain. And it is not that color by a long shot
Reactions: splitoak
I split up the rest of this cherry
Wood ID please
Wood ID please
Just kidding - you guys were right. Clearly walnut. It was waterlogged as if it had been submerged, but wasn't. Is walnut known for soaking up moisture? Thick bark was super spungy. Splits are drying really fast and the wood looks so nice.
Reactions: HDRock
Looks like walnut, last picture with pinholes looks like butternut. In either case it's a nice load of wood!
Black Walnut. Medium heat. Tons of fine white ash.
dry it , burn it, do you think it might be walnut ;), :)
Hogwildz, knows his walnut :)
I finally burned through the last of the crapload of Black Walnut I had for the last several years.
Wouldn't turn it away, but would not seek it out either.
My feelings are the same for Cherry.
Can't wait to burn it gone.
Lots of Oak stacked and waiting, and more to CCS also.
That works for me.
That works for me.
I hear ya.
I just take what I can get and burn it as needed for heat output
Thanks for advice on the walnut. Sounds like I should plan to burn it as shoulder season wood.
Walnut is not a bad wood, got me through a winter or three, best if mixed with Oak or something longer burning with less ash.
The problem I have with Walnut & Cherry is all that ash, which also covers everything below and actually insulates the wood below that is buried in ash.
Great for having coals the next morning, not so good for higher BTU output.
The Walnut ash is so fine, it actually packs down with a scoop shovel very well, but still requires cleaning much more than other hard woods.
Black Walnut is a shame to burn it's beauty, down to a big pile of ash. But heat is heat in the end.
Split it thick, and get the bark off prior to burning. Loosens up when seasoned.
