Wood insert door
Havlikn
9
Wi
I have a new wood insert with a blower fan. I get quiet a bit of heat out of it. Should I always burn with the door closed. It seems like if I leave the door open I will get more radiating heat into the room.
kborndale
619
LI
If you leave the door open you will overfire your stove.
Ctwoodtick
1,841
Southeast CT
Unless stove manual allows for it explicitly and you have a screen to catch popping embers, you’re asking for a problem.
Not to mention, the efficiency of your stove is far less with door open.
kborndale
619
LI
I took it he meant cracked, but your assessment of doors fully open seems more likely what they meant. Either way is not going to give them what they want which is more heat in the house.
Havlikn
9
Wi
When saying I leave the door open I am not saying wide open with full fire. When there is a bed of coals burnt only, I open the door about a 1/4-1/3 of the way. Always around when the fire burning. I’m just thinking that this would radiate more heat?
kborndale
619
LI
It's built to be run with the doors closed, that's how it will be the most efficient. Absolutely no reason you have to be around it either. I get the stove going every morning before leaving for work.
Ctwoodtick
1,841
Southeast CT
An open fireplace probably radiates heat in the same way but is not a good way to gain heat overall.
begreen
Mooderator
Staff member
Nov 18, 2005
99,726
South Puget Sound, WA
If the stove has a screen and is designed to operate this way, then it should be ok. I think some Drolets and Osburns offer this option. The screen is important. There can still be pockets in the core of some rounds or splits that will pop unexpectedly even in the charcoal stage.
What insert is this?
Havlikn
9
Wi
Pacific energy Neo 2.5
begreen
Mooderator
Staff member
Nov 18, 2005
99,726
In this case, there is no screen and the manual has a specific warning:
WARNING: Always keep loading door closed when burning.
This heater is not designed for open door burning.
