I have a wood stove that I need to tap the heat for radiant floor and DHW. I am using heavy gauge 304 square/rectangular stainless steel tube welded with 3/4” nipples. I have a fabricator ready to do this. I will saddle the tanks to the outside of my wood stove. I will be using taco recirculation pumps that came with the sharkbite manifold kits and pex-al-pex and aluminum plates for radiant floor. I have 2 geospring HPWH, one in the attic, one in the basement. to supplement, I have 2 navien NG tankless, one with the tank and recirc
my question, if I run only water, no glycol, is the radiant floor still on a closed loop? is the DWH separated or do I just tie it in with the radiant assuming I use the 50gal geosprings as my tanks?
