I've posted here before with great success thanks to the user group.
Woodmaster 4400, about 9 years old, in great shape.
Lately I've been out to toss wood in it and noticed after swinging the door closed I could watch the temp on the ETC drop 30+ degrees in about 5 - 10 seconds. Today I got back home around 730 and went to check it and it said the water temp was 203 (I have the low kick on point at 160 and turn off point at 170). I went and cranked the heat in the house. An hour and a half later I checked it and it said 168 so I opened the door to load it up, tossed some wood in (there was still a good bit of lumber in it) and when I closed the door hard and latched it I watched the temp go from 168 to 123 in about 8 seconds. What's going on with this thing? Is there a temperature sensor that needs to be changed every so often? It seems to see the correct water temp when I shut the door with a nice bit of force. Door rope, flapper, pumps, everything is as it should be. Would love to know if it's a sensor that needs to be replaced and where it might be.
Thanks so much in advance,
bigL
bigL
