Here are a few pics from last night's no fire - only cat and secondaries coming off the cat burn. The stove is more dirty than the chimney sometimes I think...
Bill
Bill
BrowningBAR said:How fast are those flames moving? With a VC cat stove I've found that when it's engaged the flame and glow kind of take on a liquid effect. The flames move slow and look thick. Almost bubble up from the base of the firebox. The flames lick up and then back to meet the back panel opening for the cat.
I'll take some pics this weekend to show the Encore in a cat burn.
Todd said:Nice pics, looks familiar. Does that dirty glass burn off when you turn it up, mine does but sometimes it takes awhile.
BrowningBAR said:With the stove hanging around at 300-400° what type of burn time do you get?
leeave96 said:Todd said:Nice pics, looks familiar. Does that dirty glass burn off when you turn it up, mine does but sometimes it takes awhile.
Todd,
The glass burns off when I turn it up. Sometime it all burns off totally, other times not as much. Once the temps plunge, and my daytime fires are hotter, it will burn totally clear until spring. I think the build-up on the glass is more a function of air flow moving through the firebox. With a super low burn like I'm doing, there just isn't enough air velocity across the airwash plate to keep the black stuff moving.
But I need to get in the stove and wipe down the fly ash and get the spot of burned jammies off the front glass. What/how are you cleaning the cast iron surface?
Thanks,
Bill
Todd said:I see where your coming from. I can guarantee you the Fireview will go easily 12 hours on a full load of good dry hardwood like Oak, the Keystone is a little smaller but I can still get 12 hour burns if I pack it full which sometimes can be a little more difficult because of the smaller box. 8-10 is not a challenge.
Everything I've read and heard about the VC's is the Encore has similar burn times to the Keystone and the Defiant has similar burn times to the Fireview but the VC's put out a little more BTU's during the burns because they hold more fuel. Top loading would be great, I get tired of bending down to side load, I have a little stool with wheels I can scoot around on that makes it a little easier but I'd still like to try a top loader.
If your Encore refactory poops out could you replace it with the new 2 in 1 guts? I think I heard some models can, might be worth it if you do find another VC at a decent price?
