Is this a failing Cat
spudman99
444
Yardley, PA
Short video taken yesterday. Small reload 3 hours earlier. Wood was 15% when loaded. Mostly coals and charred logs so I know there is no steam in the firebox. My current cat is entering on year 6 this winter. I burn from Dec-Apr, so probably 3,000 hours per year, max 15k hours on the current cat.
Settings were thermo at 4pm and fan on low, cat active, stt was only 220 deg or so. Not a blazing or ripping fire.
I requested a replacement cat from the dealer 2 months ago, they are not very responsive on BK products and they push Regency stoves.
My guess is that my cat is nearing its death. Should I push thru this year or try and change it in the next month or so?
Reactions: Burnin Since 1991
There may be no water that was put in the firebox,.but you're producing a lot when you burn..
I do think it's smoke tho, as it doesn't dissolve in the air,.it just dilutes. And the age of the cat is not crazy for it dying.
Is it consistently showing this, or off and on?
Reactions: BKVP
Have you looked at the combustor? Maybe it needs to be cleaned? There is a large maintenance section in your manual.
* FYI
Limited Six (6) Year Warranty: The CATALYTIC COMBUSTOR is under warranty by Blaze King for six (6) years from the date of original retail purchase. The purchaser shall pay the following share of the then current retail price for the combustor: The first three (3) years no charge, 4th year 60%; 5th year 70%, 6th year 80%. The Combustor must be returned to your dealer along with a completed COMBUSTOR FAILURE REPORT and original proof of purchase document.
If it does it through the entirety of the burn it’s shot but if it’s on and off it could be the stat opening and taking a couple minutes to handle the smoke. I’ll get a little haze on occasion throughout a burn cycle as well but it clears up. How far into the active zone was the gauge?
Reactions: stoveliker
Fighting through with a dead cat can leave drippy gooey tar in your chimney. I’m still trying to clean it from the flashing cone. They’re cheap and easy to replace, just pop a new one in.
* FYI
The warranty is 10-year on the original combustor if the OP registered for the promotional 10-year combustor warranty.
BKVP
Stoverliker is correct, that looks more like steam than smoke.
BKVP
When I've had steam coming from the chimneys there is usually a clear gap from the chimney cap to where the water condenses into steam. A disconnected plume they call it.
I thought it looked like smoke...
Reactions: Highbeam
I'd say smoke, too.
But at 15k hours, first thing I'd do is replace the cat.
I've replaced mine this year after 7 years, with about 1-1.5k hours every year, so go figure.
Reactions: Highbeam
A lot of people like to try to convince themselves that it’s just steam. Trying to postpone the inevitable cat replacement. We’re all tightwads!
  • Haha
Reactions: GG Woody
BKVP
Hi @BKVP, I didn't realize this was a thing; I thought the 10-year warranty just covered it. My stove is 4 years old. Am I still able to register?
If you still have the sequentially numbered promo warranty certificate, send it in.
BKVP
No certain depends where you buy it...
BKVP
Hi BKVP, hope you had a great Christmas! Is this what you are referring to?
  • [Hearth.com] Is this a failing Cat
Yes. Mail it in with original purchase receipt. Warranty begins day of purchase.
I'm curious about mine too. If the cat thermometer is above 1000 degrees or so, there's no visible smoke. But when I shut it down at night, and the thermometers drops to 600 or so, there's definitely visible smoke - I can't tell if it's white or not. Midwest hearth metal cat is only about 2 years old, but I may have been guilty of over-firing (however that is defined).
@BKVP I don't mean to revive an old post. I was able to get my new combusted under warranty, so thank you for that. I don't often write reviews, but I want to let you know that the customer service I received from your team was great. The rep, Avery, was extremely helpful and patient while I dug through paperwork. Once everything was figured out, the part was shipped quickly. You have a good employee and a great culture over there.
Looking forward to my first fire this year with an undamaged cat.
Thank you. They are indeed a great team, some are new, but they endeavor to help as much as they can!
Appreciate the input, now I'll buy them lunch soon.
BKVP
