I currently supplement my oil boiler heat at home (appox 1000 sf) using a Vermont Casting Intrepide II wood stove evenings and on the weekend. It works great to heat the living room where it's located, but the rst of the house just gets colder. Here is my idea. I was thinking of installing 2 6" x 18" radiators behind my stove on either side of the catolitic converter (or one 8" X 16" begin the converter section). I was then going to tied it directly into my base board heating on one side of the stove. I have very easy access in the basement to the plumbing. Along with this I was going to install a second circulation pump that I could independently control from the living room. To control the pressure, I would install a pressure relief value along with a bypass with shut off values for the whole thing as a safety precaution. I figured the existing expansion tank on the boiler would be sufficient and the pressure relief valve on the boiler would be a back up. A thermostat and pressure gauge that would be viewable from behind the stove would also be installed. I haven't yet gotten a data logger with thermocouples to check what the temps are behind all these spots, but just wondering if anybody had any thoughts or suggestions,. Thanks!
