Hi Pertzbro. I have not noticed any negative draft problems since installing the radon system. The system runs 24/7, but it's only meant to pull air from under the slab in the basement and evacuate it out at the back of the house; it doesn't seem to pull any air from the basement. In fact, the only time I ever had a problem with draft was when I tried to start a fire with a cold stove and didn't realise that the wife was running the clothes dryer upstairs... that caused a few smoky moments of panic in the basement, but we soon got it under control.... Haven't had any "bug" problems at all with the wood in the basement, but then the wood is nice and dry, been seasoning for 2 years....Chuck, does your radon system cause draft issues? Secondly, do you have bug issues with that much wood inside?
"she"
she wasn't wearing enough pink clothing, like normal, in the pics. her name is luahna, named after a nearby mountain.
The radon system should be completely sealed from inside air, the inlet to the radon pipe is installed under the concrete pad, the piping then goes to a blower and the air goes outside. The air getting sucked out from under the foundation is replaced by air coming in from around the foundation on the outside.Chuck, does your radon system cause draft issues
