I'm running an INNOVA 30 with 1k gal storage. (There's no damper; the Innova is made to run full out.)
I put a length of black pipe with a cap into the sight hole (bottom chamber). Inside the pipe is a K couple hooked to a pyrometer. The pipe protrudes about 3" (relatively not far) into the chamber.
When I run as specified with top (load) door clamped shut, The pyro. reading is 500-600 degrees.
When I run with the top door very slightly ajar, the pyro reads 1000 - 1200 degrees.
The stack temps are actually a bit lower with the door ajar than when locked. 300-400 vs. 400-500.
I noticed that the boiler temp goes to 180-190 with the door ajar, but 170s with it locked.
With the door ajar the boiler consistently takes my tank (top reading) from 140s to 170s on 1 load of wood.
With the door locked...140s to mid to high 150s. (one load of wood)
Any thoughts on this data?
