Bought a harman in 2005 and it's been great. Expensive, but great. Ran good every year till this one. It starts and burns, but, it doesn't get to a full burn. The status light blinks 4 times. Does anyone know what 4 blinks means?
Room temp sensor failure? Is the sensor connected all the way in the back? I have knocked mine loose before and it stayed in pretty much a maintenance burn because it didn't know what to do.
4 Blinks"Can only occur in Room Temp Mode and indicates room sensing probe has failed or is not installed. If a room sensing probe id then installed then the error will reset". Just happen to have the manual sitting next to me
I'll second that. Perhaps a mouse or cat ate thru the wire. You may need to switch to Stove temp mode if you find it's a failure of the room temp probe.
4 flashes: This error may occur
only "Room Temp" and indicates that the probe
the room temperature detection is not installed
or has failed. If you install such a probe to
Following this issue, the status light is automatically
reset
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
