    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. 4 cords New Member
    central ct
    just wondering what temp other quadra fire 4300 step tops run at,my tep gauge is on the step area between top and bottom flats-on the angled area.Another on the pipe 18 " up from stove ,try to keep pipe temp in clean burn range and stove is 175-200 more.Thanks
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    I'd place the thermometer on the top step about 6" from the flue for the hottest readings. What temperatures are you seeing there and at what stage is the fire?
  3. fishinpa Member
    SE PA
    I'm no expert (1st year burner) so this may not mean much. I got into my first multi-day burning this weekend and found the hottest spot for my thermometer (QF 4300 w/fan, ash pan & legs) to be just above the door on the left side front of the stove. I also have one on the stack about 24" above the unit.
    I 'thought' putting the thermometer on the top step would not truly reflect the heat of the firebox, due to the fact that the fan blows on the bottom of that plate to eject the heat into the room. I pretty much assumed the same about the lower plate as the air coming off the bottom of the upper step crosses the top of the lower step.
    I look forward to hearing more about others thoughts on this.
Thread Status:
