try pull pork instead of contemplating + more beer faster! = higher octane either way, be4 the aftermathJags said:I sometimes stay awake at night thinking about this - oh, wait a minute, no I don't. I stay awake thinking about pulled pork samiches and beer. By bad.
dunno, but overdrafting can have serious consequences beyond being a temporary PITA.Pagey said:Okay, pook, I just have to ask...and understand I ain't flamin' or hatin' in any way. But are you convinced that every stove (or at least 8.5/10) is going to overdraft? I can't count on both hands/feet the number of times I've seen the now infamous Gulland's Florida Bungalow Syndrome link this season alone.
I am honestly, 100% genuinely curious.
~*~vvv~*~ said:dunno, but overdrafting can have serious consequences beyond being a temporary PITA.Pagey said:Okay, pook, I just have to ask...and understand I ain't flamin' or hatin' in any way. But are you convinced that every stove (or at least 8.5/10) is going to overdraft? I can't count on both hands/feet the number of times I've seen the now infamous Gulland's Florida Bungalow Syndrome link this season alone.
The problem with barometric dampers is, the reduced updraft might adversely affect the secondary burn, reducing efficiency and increasing emissions. Further, the intrusion of room-temperature air into the flue cools the flue gases, causing increased creosote formation. Finally, if the increased formation of creosote leads to a chimney fire, the resulting extreme updraft will pull the barometric damper WIDE open, and could allow the chimney fire to rage out of control.
Battenkiller said:Lowering flue temps to fix burning problems is never a good idea IMHO. Control of air at the intake rather than at the exhaust is one of the cornerstones of modern stove design theory.
even safer is to spray water into the baro & not have to open the door of stove, fire extinguisher also=gonna suck into chimni right? baro + chimnifire is bad unless it dont hurt the chimniBattenkiller said:If you read the whole Florida Bungalow paper, you'll see that the use of a barometric damper to ameliorate the problem wasn't what he suggested doing. Why?
http://www.chimneysweeponline.com/hoxdraft.htm
How will the plastic bag of wet newspaper work if all the air is getting sucked in above the stove?
BrotherBart said:Battenkiller said:Lowering flue temps to fix burning problems is never a good idea IMHO. Control of air at the intake rather than at the exhaust is one of the cornerstones of modern stove design theory.
If he ever buys a wood stove or wood furnace he may figure that out.
heart feels, brain thinx. modern oil burner uses barodamper to stabilize draft. i see cup of creo from chimniclean & wonder how fat a chimnifire that could produce? LOLShari said:BrotherBart said:Battenkiller said:Lowering flue temps to fix burning problems is never a good idea IMHO. Control of air at the intake rather than at the exhaust is one of the cornerstones of modern stove design theory.
Whole heartedly agree with you both, BB and BK!
Shari
~*~vvv~*~ said:that barometric dampers get installed on wood boiler & furnaces but not woodstoves?
