Hello all,
I came across this site and there is a lot of valuable information here however I have some specific questions that I hope I can get answered. I believe I have a laundry list of issues...
I bought an older house (built in 1980) when I got home from a deployment in 2006 and it has a very large free standing earth stove in the living room. The house is two story with an external masonry chimney. Let me preface this before I go too far by saying the house was built by the original owner and there are a lot of quirky things in this house...
I have a chimney sweep/inspector coming out on Monday to clean the system because I have no idea when the last time it was cleaned. We tend to get a lot of smoke spillage into the room when adding wood to the fire and I thought this was my first issue.
I climbed up on the roof last night with a fire going because I was curious of the size of the chimney flue, my best guess is 7.5 x 7.5 or 8x8. Smoke was pouring out of the chimney of which the crown is about 2 foot above the peak of the house. At any rate, where the eve of the roof, at the very highest point, meets the chimney I noticed smoke leaking from the side of the chimney. It was dark and I couldn't pin-point exactly where it was leaking from though. So now I'm a bit nervous and have suspended "fire operations" until the sweep comes out to take a look... Also, there is no chimney cap, it's just open...
So, now that I've given my best guess as to the chimney flue size, 7.5x7x5 square... this only causes me to have more questions... the earth stove uses a rear exit stove pipe, and it's square, and BIG... and I mean it's like 8 x 10. This pipe exits the rear of the stove, goes through the brick hearth, and into the chimney where I assume it makes a 90 or fits into a "tee" to vent the smoke/exhaust upwards into the chimney.
With all that being said, it would seem to me from reading that things aren't quite right at all...
1. At first glance it would appear that I'm "necking down" from the stove pipe to the flue, which isn't correct... is this assumption right??
2. I haven't found any instances of this large square stove pipe being used, it's always round in my research, and it's never this large... is this some sort of afterthought?
3. The earth stove of course isn't made anymore and the manual doesn't tell me much but the door "drops down" from the front to load wood, when we do this, without a careful balet of opening windows etc to get it to draft right, we will quickly fill the house with smoke, which is aggravating...
4. I think this may be my biggest and most pressing issue, the leaking chimney near the top... what can be done about this?
I apologize for a long winded and probably vague description, I'm new to this area of home ownership and really want to take care of our home...
Can a round stainless chimney liner be placed in a square flue? If so, how on earth do I connect this huge square stove pipe to this round tube in the flue? I'd like to think this option would be best in that I could then add a proper chimney topper to it and it would eliminate the leak...
My dad thinks we should tear the chimney down and frame up and build a new chimney enclosure with regular pipe... we're wondering why would one build a masonry chimney for a free standing wood stove... one of those "quirks" I mentioned... If I can help it I'd rather not start down this path... it's a pretty house that's two story with cedar siding and I also noticed that the chimney has pulled back from the house by about a half inch... again, best guess...
Again, I apologize for this long winded series of questions and conjecturing... I'd like to think I'm a pretty resourcefull guy but this all new to me and I'd rather not burn our home down in the process, as I'm sure you can understand
I appreciate any help or words of wisdom from the forum... I'd happily pay with some good belgian beer I brought back with me from my last deployment (to the UK, lucky me, no desert this time!) but it's tough to mail, sorry.
Take care and thank you again
Casey
Casey
