Avalon Astoria Firebrick Removal ?
LRF
7
Hello !
I have a a Avalon Astoria that is either a 2006 or 2007. I the firebrick supposed to be taken out and cleaned behind? Frequency? I cant get mine out? Suggestions? What am I missing?
Thanks !!
my Newport bay has two retainers on each side of the firebrick that need to be lifted for removal. if its been a long time they might be seized.
not sure if the Astoria is the same or not...
Do you have the manual?
The Astoria has 2 clips in the upper corners. You slide them, then remove them....the "firebrick" lifts right out.
I have an 2007 owners manual I can send you if you need it.
And yes, it should be removed during cleaning.
Hello
You can remove it and paint it, here is what I did.
Which color scheme do you like better?
I painted the entire firebox and top heat exchanger baffles VHT Flame Proof 2,000 Deg F flat black.
Then painted the back of the fire box flat black.
Then 1200 Deg F Stove Bright copper on the firebrick with the Surf Sand on the mortar for 1 finish look
or
White VHT flame proof for the mortar and Stove Bright SurfSand for the firebrick in the last pic!
  • Avalon Astoria Firebrick Removal ?
Some of the older versions of that plate did not have the relief cut under the drop chute and the heat would warp the plate thus making it kinda a wicked pain to get out. You have to lift and lean it forward slightly. There isnt much behind it and of you cannot get it totally out, vacuum what you can and say good enough. Cleaning the back through the side access doors is time better spent.
Then 1200 Deg F Stove Bright copper on the firebrick with the Surf Sand on the mortar for 1 finish look......
Gee Don, I wonder where you got that idea from?
:rolleyes:
