For you BK Princess owners. What are your realistic burn times? I'll be using hardwoods only,. 950 sq.ft. wide open, fully insulated basement (except floor).
Thanks.
Thanks.
NATE379 said:No concern with stove temp, just concerned with house temp. No trouble holding house at 75+ even in sub sero temps.
Highbeam said:Burn times are way more important than temp of burn. You just make sure you have a big enough stove and keep it burning which is much easier with double digit burn times.
rdust said:We would also need people who give us their burn times to weigh the wood before loading the stove.
Hass said:in theory of course.
Hass said:i don't know if you guys with know but the BK stoves are using thermostats as air control.
so stoves always put out the same amount of heat at various settings, IE 1, 2, 3.
and larger stoves with a larger stovetop at 500 degrees will put out more heat than a smaller stove with a top at 600 degrees.
make sense sorta?
HotCoals said:You wont see high stove top temps..no need to.
Mine when reloading on a hot bed will work it's way up to 450 or so running off the cat.
But after 4 or 5 hours it will settle in at 350-400 for a long time.
I would buy another cat stove in a heartbeat.
After 12 hours I'm still close to 350.
2500 two story colonial ...decent insulation.
But last night I reloaded and had the cat on and the air wide open and forgot about it for about a 1/2 hour.
Stove top temp was 700...cover over cat was red hot!
Man there were flames going on..shut the air down to 1 and I had flames coming off the cat big time for at least 10 mins...huge flames!
I have no idea where the fire gets the air for that..I head that fire can make it's own oxygen ...don't know it that's true.
rdust said:Even with the t-stat you're not going to get a steady stove top temp for the entire burn cycle.
SolarAndWood said:I don't use a stove top thermometer, but I often open the tstat all the way up about 2/3 of the way into the burn when I am going for max output. I think the graph in the brochure showing the output over the course of a 40 hour burn is pretty representative of what happens if you just set the tstat and let it do its thing. FWIW, 100lbs of a wood (locust or equivalent) in a single load is a lot in a wood stove given that you are going to get a predictable controlled burn out of it without fear of it going nuclear. I always load it all the way up no matter what time of year.
Hardrockmaple said:Thank you to the Princess owners who replied, your times are as I had expected. Now, BK Princess or DW Large...tough decision for me as I really like the side load thing and my little DW has served me very well over the years. Thanks again.
Highbeam said:Hardrockmaple said:Thank you to the Princess owners who replied, your times are as I had expected. Now, BK Princess or DW Large...tough decision for me as I really like the side load thing and my little DW has served me very well over the years. Thanks again.
Good lord, that is not a tough decision at all. The VC prodcut will always be at a huge disadvantage due to extremely poor warranty history and coprorate structure. Their designs suck. The front air inlet holes are not compatible with outside air hookup. They have two or three manual intake air settings. Cast iron looks nice is from China with many gaskets and seals to fail. Sideloading is only important on a stove that is shallow. The BK stoves are very square to allow easy north south (stright in) loading. BK has a THERMOSTAT!
Old VC stoves were one thing, they built a wonderful reputation decades ago. They sold out to a nasty coproration and now the brand is much much different.
You've got only two factors helping the VC. They look much better on the hearth, and they are cheaper. Just about everything else is very inferior.
certified106 said:Hardrockmaple said:Thank you to the Princess owners who replied, your times are as I had expected. Now, BK Princess or DW Large...tough decision for me as I really like the side load thing and my little DW has served me very well over the years. Thanks again.
I have burned wood in the same Dutchwest XL for over twenty years. I have never understood the bad rap that this stove has gotten as it is a very capable decent looking stove with essentially no design changes other than removal of the shaker grate and the addition of the air wash system so I understand your dilemma. The price of the XL is extremely reasonable also when you consider you can get one brand new for $1650. The Princess does have the added benefit of the thermostat which is extremely nice. Really it just boils down to how much you wan to spend and if you need a t-stat. On a side note how is your draft? If you have plenty of draft you could always opt for the XL and run it on a 6"chimney you just can't use the fireplace screen with a 6" chimney. It's A tough choice good luck!
